View ACE Statistics
View ACE statistics to ensure that the filter operates correctly.
View ACE statistics:
Based on your hardware platform, the output can display the ACL packets by ACE type or Primary Bank or Secondary Bank.
Switch:1>enable
Switch:1#show filter acl statistics all
Acl Global Statistics Table
Acl Id Acl Name Acl Type Acl Sec Acl Sec Acl QOS Acl QOS Acl Acl
Packets Bytes Packets Bytes Packets Bytes
1 ACL-1 inVlan 0 0 0 0 0 0
2 ACL-2 inVlan 0 0 0 0 0 0
Displayed 2 of 2 entries
Acl Default Statistics Table
Acl Id Acl Name Acl Type Primary Bank Primary Bank Secondary Bank Secondary Bank Acl Acl
1 ACL-1 inVlan 1360 92480 1360 92480 2720 184960
Displayed 1 of 1 entries
IPv4 policer statistics for red, yellow, and green packets are available on VSP 7400 Series. Statistics display as numbers, which represent the hit number of packets and bytes.
Switch:1#show filter acl statistics 3 3 policer
Acl Ace Policer Table
Acl Id Ace Id Packets Bytes Green Green Yellow Yellow Red Red
3 3 29964026 106591916 142584 14254 142574 277225 28869904 10275810600
View filter acl ace policer statistics on VSP 4900 Series.
Only IPv4 policer statistics for red packets are available on VSP 4900 Series. Yellow and green packet counters are not supported on VSP 4900 Series. Statistics display as numbers, which represent the hit number of packets and bytes.
Switch:1(config)#show filter acl statistics 3 3 policer
3 3 29964026 106591916 N/A N/A N/A N/A 28869904 10275810600
View filter acl ace statistics with no policer configured.
10 1001 0 0 N/A N/A N/A N/A N/A N/A
View filter acl ace statistics with filter ACE enabled and policer configured, but the filter is not hit or there is no traffic running.
Switch:1(config)#show filter acl statistics 10 1011
3 3 0 0 0 0 0 0 0 0
View filter acl ace statistics with filter ACE not enabled and policer not configured
The following table defines parameters for the show filter acl statistics command.
Variable |
Value |
<1-2048> |
Specifies the ACL ID. |
<1-2000> |
Specifies the ACE ID. |
policer |
Specifies the policer parameter for the command. |
